Wildfire - PRO/Mechanica
  • Thread starter Thread starter mikes
  • Start date Start date
M
mikes
Guest
Hello simulators,
I am trying to run a pendulum model.
After doing all the work and trying to run I get this message in the
info
window:
"No such feature exists
Feature:MECMOTENG_INHOUSE
License Path C:\Program Files\ProEngineer Special
Edition\text\licensing\sw_license_email_59512.txt;
FLEXlm error: -5,357
For further information,refer to the FLEXlm End User Manual, available
at"www.macrovision.com" "
I checked the feature.dat file and MECMOTENG_INHOUSE is listed. Also,
I
looked at the license file and Mecanica motion is mentioned as well.
Is there a system variable that has to be set?
Is there somewhere some information regarding the system variables or
paths where special files have to be on?
TIA ,
Michael
For pro/Mechanica motion you need C++ compiler to be installed in your system. And after you install this set environment variable
MM_C_HOME or something like this to the installed directory.
BTW why don't you use MDO for your case. Don't you have MDO license?
Israr
