Width Relationship Inquiry
MrBerg
CA
Hello all,
I just recently started a position at a new company which uses SE. I was with a company that was using Solid Works. So far the swtich over hasn't been too bad. Most of the stuff is very similar.
There is one command or function that I have not found in SE that SW did quite well. In the assemble/mate mode I haven't found the "width" mate that SW had. Is there a similar relationship that SE has? For those that haven't worked with SW, it allows you to center a part between 2 parellel surfaces.
Thanks!
I don't think so.
Suggest create reference planes in the center of each part and align those.
KENAT, probably the least qualified checker you'll ever meet...
