Why this error poping up after completing the sketch?
  • Thread starter Thread starter kingston123
  • Start date Start date
K
kingston123
Guest
I am trying to draw a threaded hex screw.
Step 1: I successfully placed the point and constructed the helix: View attachment 2156
Step 2: I select that point and construct a profile. View attachment 2157
Step 3: While exiting the profile, this error pop up: View attachment 2158
I'm not sure I'm following the steps, and without seeing the tree history, I have to guess at what you've done.
Did you draw the thread profile in Sketch.2 ? Sketch.2 should only be the point that is used to define the helix curve. The thread profile should be drawn in a different sketch.
In a previous post, you included a link to a video. Go back and watch that video very closely. He goes fast, but all the steps are there.
There should be a Grove to cut the threads into shaft of the screw.
If I choose Grove then what is the use of Slot feature in CATIA software?
You are right - the Slot command is used to cut the thread into the shaft, not the Groove command. My mistake - sorry.
(I edited the post above to remove the erroneous information)
