why product rotate in Catia assembly when use contact constraint?
Bodesya
1
Hi
ia have a problem when i set contact constraint on two surface those surface contact But one of them rotate 180deg
how can i choose to rotate piece or not when using contact constraint?
here two picture of my problem
thanks
You need to define an angular constraint between the two parts. Something like a Parallel between centerplanes.
solid face are oriented outside the solid, by selecting the 2 planar face catia also match opposite direction.
for what you want you should use coincidence with same direction
Eric N.
