why isn't ProDimensionTextGet() used?
  • Thread starter Thread starter api303
  • Start date Start date
A
api303
Guest
int UserGetDimensionText()
ProError err;
ProSelection *sel=NULL;
ProDimension dim;
ProSolid solid=NULL;
int type,dim_type;
ProLine *p_text = NULL;
int n_sel;
int dim_id;
char temtem[50];
int n_text;
ProCharLine line;
ProMdl model;
err=ProMdlCurrentGet(&model);//pz 2.27
if(err!=PRO_TK_NO_ERROR) printf(model is NULL! \n);
ProArrayAlloc(0, sizeof(ProLine), 1, (ProArray*)&p_text);
printf(hanshuA has called!\n);
ProUtilMsgPrint (gen, TEST %0s, Select dimension: );
printf(hanshuB has called!\n);
err = ProSelect(dimension,ref_dim, 1, NULL, NULL, NULL, NULL,
&sel, &n_sel);
printf(hanshuC has called!\n);
if( (err != PRO_TK_NO_ERROR) || (n_sel < 1) )
return -1;
err = ProSelectionModelitemGet (sel[0], &dim);
if(err!=PRO_TK_NO_ERROR) printf(selection is NULL! );
dim_id=dim.id;
//dim_type=dim.type;
err = ProDimensionTypeGet (&dim, &type);
if(err!=PRO_TK_NO_ERROR) printf(ProDimensionTypeGet is NULL! );
dim_type=type;
//dim_type=PRO_DIM_PARAM || PRO_REFDIM_PARAM ;
printf(dim_id value is : %d\n,dim_id);
printf(dim_type value is : %d\n,dim_type);
err = ProDimensionTextGet (&dim, &p_text);
TEST_CALL_REPORT(ProDimensionTextGet(),
ProTestDimensionMenu(), err, err != PRO_TK_NO_ERROR
&& err != PRO_TK_E_NOT_FOUND);
if (err == PRO_TK_NO_ERROR && p_text != NULL)
err = ProArraySizeGet ((ProArray)p_text, &n_text);
printf(n_text=%d\n,n_text);
if (err == PRO_TK_NO_ERROR && n_text)
printf( Dimension text:\n);
for (i = 0; i < n_text; i++)
ProWstringToString (line, p_text);
printf (line= %s, line);
ProArrayFree ((ProArray*)&p_text);
return(1);
hanshuA has called!
hanshuB has called!
hanshuC has called!
dim_id value is : 1576
dim_type value is : 9
n_text=-1
