Why I encountered the spaacis/src:UNITS_NOT_EQUAL problem?
fenfam
Materials
CN
I'm doing multiscale research, so usually the python scripts need to be executed many times, but it always show these like below,
*** Warning (spaacis/src:UNITS_NOT_EQUAL)
save units not equal to the restored units
When I rerun the scripts, it does not show these errors until the scripts are excuted several times, could any one provide some suggestions, thanks for any help.
Do you get any additional error/warning messages in log files or just this one ?
I check the log file, it is always stucked in this line 'run standard.exe', then stopped to proceed .
I also try to manually stop the job with 'abaqus job=jobname terminate', it did not work and was still stucked in this line.
By the way, I was using MATLAB to system call these lines, so when it occurred , I had to 'ctrl + C' to stop the whole program and then rerun them.
Especially, dut to the force stop, if I delelete the current job temp files and rerun the abaqus python scripts, it could still work well, but I have to use these scripts in MATLAB parfor iterations, so manual control is not realistic.
