It's a fairly common occurance in my work that 4140 quenched and tempered shaft, when machined to reasonably precise tolerances (e.g. 0.1mm TIR over 500mm, for a Ø120mm shaft), needs to be 'rested' for 24 hours or more between the last few passes on the lathe, to let it distort, so that there is no distortion left to happen after the final pass.
We are talking about shafts with say 20-30% diameter removal. There is no elevated temperature annealing in the process.
Now, I understand why it would move during annealing (yielding of the areas of highest internal stress as the temperature weakens them), and I understand why it would move during machining (uneven removal of internally stressed bits of steel, and maybe even microstructural changes from the temperatures/stresses at the cutting tip), but what I don't understand, is how it is still moving hours after machining is done?
What's happening? Ongoing phase changes at room temperature? Ongoing yielding or stress relief?
I would have thought all of those would happen basically instantly or in the first few seconds after machining?
