Why does ethernet appear to be such an easy plug & play imlementation that avoids the hassles of RS-485 with grounding, biasing, termination, common mode & noise?
I've torn my hair out over the years with local RS-485 networks that aren't any longer than 100m in length, that have had all sorts of 'electrical' problems that just don't seem to appear with ethernet in the same environment. The 485 work was done using good practice: twisted pair signal cable, not running cable in high voltage trays, limited T spur length, etc.
What is it about ethernet that makes it work if the cable connector is wired OK?
Dan
Dan
