1) Open <your path to SW>\samples\design portfolio\two_bolt_flange.sldprt
2) Click the "Make Drawing from Part/Assembly" icon right next to the Save icon.
3) Press OK to accept the defaults.
4) Left click in the drawing to place the part
5)Double-click on the part to enable the 5 drawing display mode icons that are in the same toolbar as the save icon and the "Make Drawing from Part/Assembly" icon just used. The display modes are: Wireframe, Hidden Lines Visible, Hidden Lines Removed, Shaded With Edges, and Shaded.
My problem is that I can get the data in only the Wireframe, Hidden Lines Visible, and Hidden Lines Removed display modes. The data in the shaded display modes cannot be extracted. Also when exporting DXF/DWG, you can only get the data in wireframe mode. Any texture or material data does not come across. I want to be able to extract the picture that I see in the drawing when in the shade display mode but cannot.
Hope this helps clarify. Again, thanks for the help everyone!
