Why Am i have having trouble mirroring 1
ME82
Im creating a basic sketch of a parrallelogram, but everytime i try to mirror it over a centerline it aint working. I want to mirror it in the front plane.
Mirror the sketch or the feature? Mirror sketch with centerline, mirror feature with plane.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP2.0 / PDMWorks 05
ctopher's home site
FAQ371-376
FAQ559-1100
FAQ559-1091
FAQ559-716
To mirror a sketch, the centreline needs to be in the same sketch.
[cheers]
Making the best use of this Forum. faq559-716
How to get answers to your SW questions. faq559-1091
Helpful SW websites every user should be aware of. faq559-520
It does mirror it, but when i try to mirror over a certain distance kinda of like lets say i want this letter
a to be mirrored all the way here a
with a centerline in between but it wont do it.
Make sure you're picking all your sketch segments you want to mirror.
Remember:
You cannot mirror construction geometry (dashed line).
You shouldn't have elements crossing your centerline.
After you select all the sketch segments you want to mirror, CTRL-Select the centerline (dashed line, construction geometry) that you want as your center, then use the mirror function in the Sketch toolbar. It will work.
By definition, your centerline will always be centered between your mirrored geometry.
Jeff Mowry
Reality is no respecter of good intentions.
What is the distance? Inches, feet, miles?
Can you post an image including the Feature Manager? See faq559-1100
[cheers]
If you can re-make the sketch, it's better to sketch the centerline, then activate mirroring and draw the sketch "directly mirrored". In that way the program automatically resolves potential mistakes such as centerline-crossing (it will prompt you), and you can add dimensions and constraints in watever part of the sketch, no matter "left" or "right" (of course, the symmetry is implicit, so be careful not to over-constrain your sketch...)
Claudio
Thanks Cloche, I did not know that. Good tip. [thumbsup2]
[cheers]
