Why a sine wave output of a voltage regulator?
Steventyj
CA
I was in the lab today working on a circuit and it wasn't behaving as I expected. I diagnosed the problem as an irregular supply voltage from a 7805 voltage regulator. I am supplying it with 15 volts (also tried 12 volts) and getting 5 volts out. When the resistance of the circuit is low enough (does not have to be very low, 660 ohms for example) I start to get a sine wave along with the DC voltage. I realize that the regulator may start behaving irregularaly at higher current draws (lower resistances) but I am talking about milliamps. Any ideas?
Thanks,
Steven
Hi, you need caps on the ip and op to get stability, try 470nF on the inp and 220nF on the outp. You could even try reading the datasheet.
Brings back memories. Had a Action Pack position sensor module in a project that was 120V AC. Design then forced us to mount it remotely and we asked the factory to make a bunch without the transformer. The factory decided to also remove the input capacitor to the regulator. When we installed it we had this strong 1 mhz in all the signal lines. That regulator was singing like a canary. Also, in the lab they had built a FET ampliier for an accelerometer. I noticed they had a cap from the output to ground. I asked what that was for and they said it would oscillate without that. There was a length of coax on the FET's gate that looked like a tuned circuit. Internal capacitance of the FET was enough to start it. A 100 ohm resistor in series with the gate lead was enough to dampen it. Almost anything can become an oscillator!
Page 4, Note 2: All characteristics are measured with capacitor across the input of 0.22uF, and a capacitor across the output of 0.1uF....
Alright I geuss I will have to start reading those more carefully. Thanks for the help guys, im in the lab now and its working.
