I have a forced air funace and a GreenTek air to air exchanger in my house and want to install a whole house humidifer, I'm thinking the Honeywell HE260 Bypass Flow Through Humidifier.
My question is this: The air to air exchanger is controlled by a humidistat mounted by the thermostat, is there a way to control both the humidifier and air to air exchanger from the same humidistat?
Or if I have to install a new humidistat for the humidifier will it and the air to air exchanger fight to add/remove moisture? I don't want to create an issue where they are both always running becuase they counteract eachother.
Sorry if this is dumb question, appreciate any insight you may have.
