Who can I join/unite lines in CATIA 1
avictor
Computer
ES
I´m tray to join/unite two lines in one line, I´m can do this with the command join, but I need to create only one line, without internal point. Who can I do?, when I extrude this join catia create two surfaces, and is very important for me, that catia make only one.
Thank you very much for your attention
Once you've created the join you should use the smooth command and select tangent continuity - this will create a single curve with no internal knots.
When you join, use the federation option, own tab in the join feature.
Then the join will be recognized as one element
that is if you have the federation license. Not all config have that function.
Thank you for your attention. Now I´m taking a look this options.
