Which software do you use for CAD Design?
  • Thread starter Thread starter mepservices
  • Start date Start date
I have used AutoCAD, Solidworks, Vector works for CAD design.
We use Autocad civil 3d 2015, also ProgeCAD with customized plugins.
I have used AutoCAD, 3Ds Max, Solidworks, CATIA, ArchiCAD for CAD Design.
Architectural design studio
3Ds max is the best Cad design software. like it.
I use 3dsmax, Solidworks, Autodesk, and Autocad.
I personally use FreeCAD for CAD design.
Fusion 360 and OpenSCAD is also good
I Use AutoCAD
Hi Guys,
There are softwares like SketchUp Pro, AutoCAD, CATIA V5 and SolidWorks. I recommend you to use AutoCad as it is easy for beginners to learn.
Thanks & Regards
Cad Design Service
Roger King
You can use autocad or solidworks
I am using autodesk and Rhino
Excellent thread! Thank you!
I mostly preferred Autodesk for CAD design. We have most of the projects related to woodwork design and this software makes the design process for wood furniture simpler and more powerful whether it is for cabinet design or joinery design, etc.
I regularly used Autocad, Catia & UniGraphics Designing Tools for 3D and AutoCAD for my simple 2D drawing. I think I'm conservative with the tools I use, but they're good, that's the reality.
I use Rhino (and am actually an ART for McNeel) and Selfcad when I want to do something easy or have an STL I need to tweak
revit and autocad are the best one out there
I uses this two software
AutoCAD LT
Rhino.
Thank you so much for this information.
Have used AutoCAD but recently CADdirect
CADdirect
As there are many Softwares available in the market that deliver the CAd drafting and rendering projects. But as per my opinion, you can use Autodesk and Revit software that rendering High-quality output with perfection and easy to use, If you are looking for Outsourcing CAD Drafting Services than We specialize in delivering outsource 2D CAD drafting services, 3D CAD design, and BIM modeling services at an affordable cost for quick problem solving and efficient decision-making processes with cutting-edge technology.
