Which software do you use for CAD Design?
  • Thread starter Thread starter mepservices
  • Start date Start date
M
mepservices
Guest
I use AutoCAD ,RHINO and 3dmax. and MAXSURF for ship hull design
I am using regulary solidworks, autodesk, autocad, max, pro engineer etc. for the cad design.
AutoCAD 2010
i use Autodesk Inventor 2010 for just about everything i do (mainly performance car parts)
Autodesk Autocad 2010 isnt bad for some parts
ocasionally i use Autodesk Alias
i tried using Solidworks a few times - but i just dont like it at all
We use AutoCad, Turbo Cad, Solid works, Microstation, Vector works etc. for cad design.
Adem
I use solidworks 2012 and AutoCAD 2007. Prefer Solidworks over autocad for 3D drawings.
Hello Community,
I use AutoCAD and MicroStation softwares in my work.
Thanks and Regards,
Tony Marcou
CAD Software
Computer-aided design (CAD) is the use of computer systems to assist in the creation, ... CAD software is used to increase the productivity of the designer, improve the quality
CAD Drawing India
AutoCAD software
AutoCAD 2014 CAD software takes design further
Design and shape the world around you with the powerful, connected design tools in Autodesk® AutoCAD software. Create stunning 3D designs, speed up documentation and connect with the cloud to collaborate on designs and access them from your mobile device.
I use AutoCAD and TurboCAD Designer...
The CAD software
The solidworks, autodesk, max, pro/e be used in most of time.
Jevny Technology in China(Rapid Prototyping and Tooling)
Using Autocad
I simply use Autocad for its simplicity and support.
CAD design software is used in virtually every industry including the creation of landscape designs, bridges, office buildings and movie animation. CAD, also known as computer-aided design and drafting (CADD), is the use of computer technology for the process of design and design-documentation. If you work in the architecture, mechanical or engineering field you have probably worked with CAD software, which can include creating a 3D model of a design, applying material and lighting effects, and documenting the design with dimensions and other annotations.
I use Auto Cad and Rhino
CAD Software
I use CATIA
