guys I have question for you....
when it is needed to put shear wall in a building?
what is the basis or criteria to consider that the building need to design with shear wall???
there is an instance that we design concrete two storey residential building. We design the frame as a lateral load resisting frame. We used masonry exterior and interior wall. When we submitted the plans for issuance of building permit, the building official required as to put shear wall. It is my question why we required to put shear wall since we design the structure safe to any anticipated load that may occur and I don't have any idea where the shear wall should be located. The building official doesn't explain why they required us... I want to know what to explain why and when does a particular building need to design with shear wall..
thanks to any input you may have....
