Hi all,
I'm working on a part and am not sure if the bending stresses should be accounted for in a welded on nut plate and d if needed how that would be done.
I'm welding the attached nut plate to a box tube and a preliminary calculation shows more that adequate strength in the weld [0.707×(2×2.5in+2×3.75in)×0.3125in×68,000psi=188kip]. My question is if and how I accommodate the fact that the nut plate is relatively thin compared to is foot print. If the nut plate were even an inch thick I would assume this is sufficient, by UT at 3/8 I am not confident.
I appreciate any help that can be provided.
