In my experience if you have a pressure vessel with MAWP > 15 psig, you'll likely need to provide a PSV or have calculations on hand showing you considered all the scenarios and the system is protected by design. Some states have size, pressure, and temperature exemptions so maybe the 190L dryer falls into that category (below 150 psig, less than xx dimensions, less than 300F, for example). Alternatively I've had projects where we did calculations showing the dryer was protected by design and an OSHA or NB inspector said "I don't care, add a PSV"
