REPLY TO
nkwheelguy (Automotive) May 27, 2004
Mrrch has it right. Being a wheel designer, the way to calculate wheel offset is done as follows:
1. Measure the inner rim width with a set of inside vernier calipers. Make sure you are on the flattest surfaces & not hitting any radii. The inner rim width is the distance from the backside of each flange, or the distance between the bead seats. Take this number and divide it by 2.
2. Measure the inner flange width with vernier calipers, making sure not to contact any radii on the flanges. Subtract this result from the calculation done in step 1.
3. Measure the depth of the mounting surface from the inner flange (top of where the balance weights are clipped) using a depth caliper & 10mm flat bar. Subtract this measurement from the result in step 2 & now you should have your offset. If you are measuring in MM, round to the nearest whole MM, as typically there are no target offsets in tenths of a MM.
Now, to make things more confusing, there ARE negative offset rims and positive offset rims. Negative offset rims would be the type that stick way out when mounted on a vehicle.
Hope this helps someone out!
Tim Flater
Senior Designer
Enkei America, Inc.
HEY TIM:
I had a bit of a hard time interpreting this post, so let me see if I get this right.
OFFICIAL Wheel 'width' is the distance between the insides of the flanges, which is about 0.8 to 1.1" narrower than the UNOFFICIAL outside 'width' of the flanges that most people think of.
Next, offset is the distance from the wheel's natural centerline to the mounting backside of the boltholes pad, with NEGATIVE OFFSET meaning MORE distance from the unseen inboard flange to the unseen mounting pad than the LESSER distance from the seen outboard lugnut mounting pad to the seen outboard flange!
And, finally, the 'backspacing' is the distance from the tire mounting bead to the inboard mounting pad, so that BACKSPACING = 0.5000*(the bead-to-bead distance) - (offset measurement) ..... so that negative offset INCREASES Backspacing and positive offset DECREASES Backspacing .....
I am trying to get this straight so I can make an informed decision on the purchase of new 17" rims for my 94 LEGEND 6-SPEED with 6.5"x16"x(65)mm offset rims!
Dudes on EBAY seem NOT to know what they are talking about!
Thanks so much! Jeff Kay, Risk Analyst, Automotive Loans.
