I am designing a wheel hub for an off road buggy. I am trying to work out what factors I have to take into consideration and what the system interactions will be.
The standard stud pattern for off road wheels is VW Wide 5 (5 x 205) so I will be using that stud pattern.
I am not sure what brake rotor I will be using. I am hoping to find something useful off a common car (any suggestions given I am Australian) if not them I will look at something from Wilwood probably like This would be better performance wise but cost would be greater.
So that leaves wheel bearings. I am undecided as to if I should go for an aluminum or a steel hub. Steel makes the bearing selection process easier. If I go aluminium it will save weight butas far as I can tell I have to use a hub bearing unit to allow for expansion but I can not find technical details on these units (sizing available etc). The SKF website has a CAD library of their bearings but I could not find the hub units in there. Any details on this sizing information and how these units should be mounted would be greatly appreciated.
Other than that it all has to be strong enough to take the weight of the car. Any help in any area would be greatly appreciated. Is there any other factors I need to take into account? Seen as I don't have a design team to bounce ideas off then this forum is going to have to be it!
