I seriously doubt you need this performance level for a motor, but to give you some idea of cost, my 6.5 digit Keithley Model 2000 bench meter cost £700. It will measure 100uOhm to 100MOhm to better than 0.01% accuracy. Agilent offer a model which is an almost direct equivalent in performance.
You should ideally look for a four-terminal (or Kelvin) resistance measurement technique as this will avoid the test leads introducing inaccuracy. This would rule out most hand-helds, but it is common even on entry-level bench instruments.
The other thing to consider is that hand-helds are portable and tend to grow legs. A bench instrument is easier to mount in a rack, and not so attractive to the 'borrowers'.
If we learn from our mistakes,
I'm getting a great education!
