Whats a good, fast, cheap sensor for a laser?
1mikef
Aerospace
I am looking for a fast, inexpensive laser sensing component. Any ideas. The cheaper the better.
What wavelength, spot size, and power? These all dictate what type of sensor is needed. (i.e. photodiodes may not respond well or at all to IR radiation)
Wheels within wheels / In a spiral array
A pattern so grand / And complex
Time after time / We lose sight of the way
Our causes can't see / Their effects.
Thanks for the reply,
650nm, Spot? .125 spot, and power I am not too sure about. Photodiodes are like 4 bucks each. Thats a little high for me. LDR's can be cheap, but I am concerned about their dissipation rate.
What do you think?
and thanks again.
Should be able to get photodiodes for easily under a buck, check Allied or Newark. If I recall, LED's also respond to light, you may want to try experiementing with a RED one.
how would I go about finding someone to help me with my circuit? Is there a firm or freelancers that are easy to reach?
With specifications and desired operation details, I'm sure many of us here would be glad to point you in the right direction or come up with a solution. Is this a homework assignment?
More like a hobby.
I want to be able to determine how long my sensor is blocked. So for starters, I need to know what type of sensor to use. You suggested a photodiode so I will look into that (thanks). Next I need to know how to wire it so that ambient fluctuation does not interfer with my readings. I just want to know if the laser is blocked and for how long.
What do you want to do with the output? A PIN diode will work in many applications.
TTFN
A black housing with a tube leading to the photodiode/xistor will help prevent ambient light from affecting the performance.
A
What sort of ambient? From experience, most photodetector sensors are like vampires; they hate sunlight.
You can also filter your detector, similar to TV remotes
TTFN
THe output I would like to read on my PC, I will have to have the sensors pigtail to fit my I/O card.
I am planning to use the black housing. THe PIN doiode is a cool idea, I will look into that.
How do I wire up the diode? Is there anything I should consider? I just want to be able to know when it is on or off, and it needs to be pretty fast.
I will probably not respond anymore until later tonight.
Thanks for all the help. and please keep any ideas coming.
For speed, you want to reverse bias the photodiode- this reduces the junction capacitance. The diode then generates a current proportional to light intensity (until saturation). You then need a current-to-voltage converter circuit (think high speed op amp). Follow this with a high speed buffer or TTL driver (schmitt?) to interface to the digital input on the I/O card. Suspect that diode responce will be way faster (10's of nsec, depending on photodiode size and capacitance) than your software (10's of msec). Suggest a narrow bandpass filter to only allow your laser wavelength to get through to the detector.
Hamamatsu, a major manufacturer of photodiodes has some good app notes, here are some links to get you rolling:
Good LucK
-Pete
Thanks for the head start. If you know anyone that would like to draw up the circuit, let me know. It started out as a simple circuit, (it probably still is), but I am sure I will need help. The schematics you linked me to will be very helpful.
Mike
The best way to reject the ambient is to modulate the light source with a -- relative high -- frequency and
use selective amplifier. Radio Schack had a 40kHz
receiver module years ago.
<nbucska@pcperipherals DOT com> subj: eng-tips
read FAQ240-1032
