What type of bolt or rivet
chu77
Automotive
May 31, 2007
I'm trying to take part this housing but it seems like it's been fasten down by a bolt or rivet. How should I take it out?
It looks to me that die cast pins integral to the housing are swaged to hold the cover on. If this is the case, I'd have a machine shop mill these heads off.
Yes I plan on reassembly, is there a way of taking it out and putting it back on?
Well, to get it apart, it looks like you could machine, drill, grind, or chisel the upset head shown in the photo. To reassemble, you might have to drill and tap if it's a boss, or replace if it's a rivet. Hard to tell exact details. You may have to discover how it's made and then come up with a plan for reassembly. Welding may be an option.
Good luck,
Mike
