You also need to know your heat exchanger size and steam side pressure drop, or at least balance it against the required water (and steam) duty. You can do this with 14# steam if your exchanger is big enough. Usually, I suspect, you know the steam pressure available, so the required flow is derived from that.
SNORGY.
