Cory:
provided the necessary explanation for what you listed as values of shear stress used in design.
As far as which of the three shear stress criteria you should use, that is a completely different matter. Can you please provide more information related to your OP?
Reply:
Cory, our application is a motor operated valve key, which is between a splined adapter and the shaft. The key is subject to torsional loading from torque from the splined adapater, which is driven by the operator. The torque is transferred through the key to the shaft. The key is
the weak link in the valve. The stress in the key is
calculated from 2T/D x W X L where T is the torque, D is the shaft diameter, W is the key width (square key), and L is the key length. The stress is then set to the allowable stress to determine what the maximum torque can safely be placed on the key without yielding the key. If the key were too strong, then something else in the valve would break, not strong enough, then the valve would not operate possibly. Over time, as river water gets intot he valve bearings required torque increases, which is why we have to know what the key can take...
