What is the meaning of ... (three dots) representing Material Chemical Composition 1
FrankGhana
Petroleum
EG
Hello Everyone, i am reviewing ASME Material A178Gr. A and the Mill test certificate i have is indicating Si= 0.036 but in the ASME Code Si= ... in the case of Grade a which i believe it should be just a trace/negligible value. Can anyone tell me the meaning of ... in the ASME Code?Thank you
This means the element is not specified.
If you go elsewhere in Section II, Part A, such as SA-6 - Table A, there exists
Note 1- Where "..." appears in this table there is no requirement.
Thank you for the update>>>> TGS4(Mechanical) found the answer rather in ASME Section III, Part A SA-6 Table B (Under permitted variations in product analysis)
