This compressor was used on Ethylene Cracker Downstream of the Quench Tower. This is a three stage compressor with x suction pressure, y discharge pressure and a z flow. However, the EPC contractor design the compressor structure/top of concrete to be 11 meters. Since this is driven by a condensing steam turbine on which below the expansion bellow is the surface condenser. From the nozzle end of the condenser, the height was 4 meters because of the NPSH requirement of the OH2 pump. Is there someone, working on an ethylene cracker with the same design?
