302Hugo
Petroleum
- Aug 23, 2006
- 58
Hey all,
Operations has had problems with the current actuated startup bypass valves. The fluid in this aplication is Blend Oil. There is currently a 30s shutoff actuator on a 1/4 turn ball valve. Because only about 1/8 of the turn is actually doing something, they find it shuts off the flow too quickly.
When I asked a vendor about a V-ball valve he said it wouldnt help the application. Is he right or wrong?
Typically what are the best valves to use with an actuator? Is this too much of a broad question?
