What is plasticity index?
yahoo123
Bioengineer
Nov 6, 2007
87
Can somebody tell me what this value represents? I know that it is the Liquid Limit minus the Plastic limit. But can someone tell me what the significance is?
How does plasticity affect, for example, compressibility, compactibility, strength, cohesiveness, etc..
When and why is high or low plasticity preferable?
Thank you so much. Yes I am totally clueless
The PI has a rough, loose relationship with the potential for being expansive under added moisture content.
As a structural engineer, my geotech buddies in south Texas many times used the PI to relate to me how expansive the clays were. A PI lower than 20 to 24 was generally a safe area...but higher than that and we would then have to respond to swelling clay conditions.
I'm sure the geotechs on this forum can enlighten better than the above.
The following was copied from a web site:
"The Plasticity Index is simply the numerical difference between the liquid limit and the plastic limit for a particular material and indicates the magnitude of the range of moisture content over which the soil remains plastic. It is a measure of the cohesive qualities of the binder resulting from the clay content. Also, it gives some indication of the amount of swelling and shrinkage that will result in the wetting and drying of that fraction tested. If some soils do not have sufficient mechanical interlock they require amounts of cohesive materials to give a satisfactory performance. A deficiency of clay binder may cause ravelling of gravel wearing courses during dry weather and excessive permeability."
The plasticity index is the range of moisture content where a given soil will behave as a plastic material. How that effect your project is determined by your experience and the type of project.
f-d
¡papá gordo ain’t no madre flaca!
