@maradona129508, I mean, this is the research you should be doing i dont know your location every province would have different vendors which would have different approved models. from the region I am from, there are a few but the main ones we use is the ION8650. i hear they are moving to the ION9000 series. I believe the difference is power quality features. I would contact your local ION (MCN?) supplier and ask them which ones are approved and go from there. I would get the main one revenue canada approved and the second one identical just not approved if you are concerned about cost. if the main one fails you can always send one back while using the other one as backup and / or get the second one approved etc. Keep in mind, revenue metering approved is a Sealed meter. so you have to send it back to the factory to get programmed/sealed. which usually takes a long time.
