SolarPrestige
Hello everyone,
Might seem like a too basic question, but comes down to being new to doing arc-flash calculations. I am looking at IEEE 1584 and where it states that there are classes known as LV switchgear, LV MCCs and panelboards. Just concentrating on low voltage with this. This standard is North American oriented, and to me in the IEC part of the world, I work with mainly switchboards, MCCs, and distribution boards (DB). Switchgear to me is the parts that go into these types of panels systems to make an assembly. The question is, what does 1584 means by the terms it uses? This is to avoid making a mistake in selecting the wrong type.
Further, I also see ETAP bus selection is adding a thing called a switchrack into the mix and it also includes switchboard, but is this my type of switchboard? So, in ETAP I have Other/MCC/Switchgear/Switchboard/Switchrack/Panelboard/Cable Bus/Open Air to chose from for a bus type. I guess "Other" isn't a concern, and open air sounds like not in a panel, free mounted. Cable bus is presumably a bus-duct distributor. The others, I can't decide between them.
Any help appreciated.
Greg
Greg
