Several MSS specifications may be applicable. A list follows:
SP-6-2001 Standard Finishes for Contact Faces of Pipe Flanges and Connecting-End Flanges of Valves and Fittings
SP-9-2001 Spot Facing for Bronze, Iron and Steel Flanges
SP-25-1998 Standard Marking System for Valves, Fittings, Flanges and Unions
SP-42-2004 Class 150 Corrosion Resistant Gate, Globe, Angle and Check Valves with Flanged and Butt Weld Ends
SP-43-1991 Wrought Stainless Steel Butt-Welding Fittings
(R 2001)
SP-44-1996 Steel Pipeline Flanges
(R 2001)
SP-45-2003 Bypass and Drain Connections
SP-51-2003 Class 150LW Corrosion Resistant Cast Flanges and Flanged Fittings
SP-53-1999 Quality Standard for Steel Castings and Forgings for Valves, Flanges and Fittings and Other Piping Components - Magnetic Particle Exam Method
(R 2002)
SP-54-1999 Quality Standard for Steel Castings for Valves, Flanges, and Fittings and Other Piping Components - Radiographic Examination Method
(R 2002)
SP-55-2001 Quality Standard for Steel Castings for Valves, Flanges, Fittings, and Other Piping Components - Visual Method for Evaluation of Surface Irregularities
SP-58-2002 Pipe Hangers and Supports - Materials, Design, and Manufacture
SP-60-2004 Connecting Flange Joint Between Tapping Sleeves and Tapping Valves
SP-61-2003 Pressure Testing of Steel Valves
SP-65-2004 High Pressure Chemical Industry Flanges and Threaded Stubs for Use with Lens Gaskets
SP-67-2002a Butterfly Valves
SP-68-1997 High Pressure Butterfly Valves with Offset Design
(R 2004)
SP-69-2003 ANSI/MSS Edition Pipe Hangers and Supports - Selection and Application
SP-70-1998 Cast Iron Gate Valves, Flanged and Threaded Ends
SP-71-1997 Gray Iron Swing Check Valves, Flanged and Threaded Ends
SP-72-1999 Ball Valves with Flanged or Butt-Welding Ends for General Service
SP-73-2003 Brazing Joints for Copper and Copper Alloy Pressure Fittings
SP-75-1998 Specification for High Test Wrought Butt Welding Fittings
SP-77-1995 Guidelines for Pipe Support Contractual Relationships
(R 2000)
SP-78-1998 Cast Iron Plug Valves, Flanged and Threaded Ends
SP-79-2004 Socket-Welding Reducer Inserts
SP-80-2003 Bronze Gate, Globe, Angle and Check Valves
SP-81-2001 Stainless Steel, Bonnetless, Flanged Knife Gate Valves
SP-82-1992 Valve Pressure Testing Methods
SP-83-2001 Class 3000 Steel Pipe Unions, Socket Welding and Threaded
SP-85-2002 Cast Iron Globe & Angle Valves, Flanged and Threaded Ends
SP-86-2002 Guidelines for Metric Data in Standards for Valves, Flanges, Fittings and Actuators
SP-88-1993 Diaphragm Valves
(R 2001)
SP-89-2003 Pipe Hangers and Supports - Fabrication and Installation Practices
SP-90-2000 Guidelines on Terminology for Pipe Hangers and Supports
SP-91-1992 Guidelines for Manual Operation of Valves
(R 1996)
SP-92-1999 MSS Valve User Guide
SP-93-1999 Quality Standard for Steel Castings and Forgings for Valves, Flanges, and Fittings and Other Piping Components - Liquid Penetrant Exam Method
(R 2004)
SP-94-1999 Quality Standard for Ferritic and Martensitic Steel Castings for Valves, Flanges, and Fittings and Other Piping Components - Ultrasonic Exam Method
(R 2004)
SP-95-2000 Swage (d) Nipples and Bull Plugs
SP-96-2001 Guidelines on Terminology for Valves and Fittings
SP-97-2001 Integrally Reinforced Forged Branch Outlet Fittings - Socket Welding, Threaded and Buttwelding Ends
SP-98-2001 Protective Coatings for the Interior of Valves, Hydrants, and Fittings
SP-99-1994 Instrument Valves
(R 2001)
SP-100-2002 Qualification Requirements for Elastomer Diaphragms for Nuclear Service Diaphragm Type Valves
SP-101-1989 (R 2001) Part-Turn Valve Actuator Attachment - Flange and Driving Component Dimensions and Performance Characteristics
SP-102-1989 (R 2001) Multi-Turn Valve Actuator Attachment - Flange and Driving Component Dimensions and Performance Characteristics
SP-103-1995 (R 2000) Wrought Copper and Copper Alloy Insert Fittings for Polybutylene Systems
SP-104-2003 Wrought Copper Solder Joint Pressure Fittings
SP-105-1996 (2001) Instrument Valves for Code Applications
SP-106-2003 Cast Copper Alloy Flanges and Flanged Fittings, Class 125, 150 and 300
SP-108-2002 Resilient-Seated Cast Iron-Eccentric Plug Valves
SP-109-1997 Welded Fabricated Copper Solder Joint Pressure Fittings
SP-110-1996 Ball Valves Threaded, Socket-Welding, Solder Joint, Grooved and Flared Ends
SP-111-2001 Gray-Iron and Ductile-Iron Tapping Sleeves
SP-112-1999 (R 2004) Quality Standard for Evaluation of Cast Surface Finishes - Visual and Tactile Method.
SP-113-2001 Connecting Joint between Tapping Machines and Tapping Valves
SP-114-2001 Corrosion Resistant Pipe Fittings Threaded and Socket Welding, Class 150 and 1000
SP-115-1999 Excess Flow Valves for Natural Gas Service
SP-116-2003 Service Line Valves and Fittings for Drinking Water Systems
SP-117-2002 Bellows Seals for Globe and Gate Valves
SP-118-2002 Compact Steel Globe & Check Valves - Flanged, Flangeless, Threaded & Welding Ends (Chemical & Petroleum Refinery Service)
SP-119-2003 Factory-Made Wrought Belled End Socket-Welding Fittings
SP-120-2002 Flexible Graphite Packing System for Rising Stem Steel Valves (Design Requirements)
SP-121-1997 (R 2002) Qualification Testing Methods for Stem Packing for Rising Stem Steel Valves
SP-122-1997 Plastic Industrial Ball Valves
SP-123-1998 Non-Ferrous Threaded and Solder-Joint Unions for Use With Copper Water Tube
SP-124-2001 Fabricated Tapping Sleeves
SP-125-2000 Gray Iron and Ductile Iron In-Line, Spring-Loaded, Center-Guided Check Valves
SP-126-2000 Steel In-Line Spring-Assisted Center Guided Check Valves
SP-127-2001 Bracing for Piping Systems Seismic-Wind-Dynamic Design, Selection, Application
SP-129-2003 Copper-Nickel Socket-Welding Fittings and Unions
SP-130-2003 Bellows Seals for Instrument Valves
SP-131-2004 Metallic Manually Operated Gas Distribution Valves
SP-132-2004 Compression Packing Systems for Instrument Valves
