what is a "soft touch" material? 1
HDS
What properties gives a coating a "soft touch " feel? There has to be more to it then just a low coefficient of friction.
How do you define and "soft touch" so that you can evaluate different materials?
What about a soft touch paint? Is it still a low durometer that creates the feeling?
I would guess (and it IS a guess..) that paints may use soft elastomers as a filler (maybe EPDM as it's use as an impact modifier in some plastics).
Just wait a bit and someone who knows what they're talking about will arrive...
H
www.tynevalleyplastics.co.uk
It's ok to soar like an eagle, but weasels don't get sucked into jet engines.
This was a question that could have gone into a dozen different forums. Like you said hopefully the right guy will come along that can explain what characteristics give these materials and coatings their unique tactile properties.
You can use a very soft material, e.g. for a soft touch handle inside a car back seat but then it's too soft to bear load. So what they do is to use a hard, load bearing material and put a soft touch coating on it. For example a paint containing soft touch silicone particles like these:
It's probably a combination of the soft elastomer and the textured surface that makes the effect.
Chris DeArmitt PhD
President - Phantom Plastics LLC
Trusted adviser to leading companies around the world
