What is a "Humming Window" (Digital Image or Speach Processing ?)
DM2
I'm doing some research that involves digital processing of video images. There is a statement in one manufacturers patent (US 6184792) which states:
For the purpose of the present embodiment, these measures are computed by performing a Fast Fourier Transform (FFT) on the temporally varying, pixel intensities. The measure of the static component is taken to be the Zero FFT term, (i.e., mean brightness value), While the sum of the three FFT terms centered around 5 HZ are taken as the measure of the dynamic component. However, similar end results were obtained when using Digital Signal Processing techniques with Humming Windows (that is not to suggest that Humming Window is the only technique possible). In addition, the dynamic component can be determined by simply counting how many times the intensity signal crosses its mean value within each analysis cycle.
I attempted to Google the term, but with little luck. I did find a PDF publication on the web titled [link gendocs.ru/docs/10/9175/conv_1/file1.pdf]"Speech Technologies"[/url], where on pdf page 181 the term is used in the context of:
Frame Length 25 ms. (Humming Window)
DM
"Real world Knowledge isn't dropped from a parachute in the sky but rather acquired in tiny increments from a variety of sources including panic and curiosity."
Look at this link for a slew of different window types and their effect on the signal's spectrum:
There may be something better than a Hamming window... just because a patent uses it doesn't mean it is/was the best choice.
Dan - Owner
