Context:
-We are trying to add a Relief Valve to protect the shell-side of a shell and tube heat exchanger
-The over pressurization scenario for the exchanger is the external fire case.
-The shell-side fluid is steam which gets condensed. The exchanger is equipped with a steam trap to evacuate the condensate
My question is: if you were to make the calculation, would you assume that the fluid state is liquid or vapor?
API 521 offers two calculations for the fire case, if the vessel is filled with liquid or gas. I'm in conflict with some colleagues as we disagree with the state of fluid.
I say that since it's a S&T and it has a steam trap, the vessel will mainly be filled with vapor. On the other hand, my colleague thinks that since there is a bit of condensate in the exchanger, it's enough to consider it a liquid case and use the liquid state calculation.
Thoughts?
Thoughts?
