What factors affect the thermal performance of fiberglass reinforced plastic sheets? Which factor has most impact on the thermal performance? Thanks for any advice.
The thermal conductivity of a composite will be a function of the thermal conductivity of its constituent components, and the percentage of each in the composite.
If you ask a specific question you stand a better chance of getting a specific answer.
JMiller1357, you are right...and shame on me for not being more careful. What I was trying to get at was that for an object, if you know one than you know the other (assuming you already have L and A at your disposal).
I believe that this also depends on the resin that you will use to make the FRP object. I am not an expert, but as far as I know FRP mats or sheets as you call it are not used as is, they are "glued" with resins to given the object both chemical and structural resistance.
