Soldier piles are used more often than steel sheeting unless the contractor already owns the sheets and can pull and reuse them.
Soldiers are used when the excavation support system does not need to retain water and resist hydrostatic pressures.
Soldiers are used when the soils are reasonably competent. Soldiers are not good in very loose running sands or very soft fine grained soils.
If displacements are a concern, soldier piles may not be as rigid as some steel sheet piling.
If noise and vibrations are concerns, drilled-in soldier beams may be better than driven steel sheet piling.
Soldier piles will not provide resistance to bottom heave, piping, or boiling at the base of the excavation.
Generally, soldier beams and lagging are not used to support adjacent structures. Steel sheeting also should not be used to support buildings unless it is the only alternative and everyone recognizes the increaded risks of using one of these relatively flexible wall systems. Along structures, it is better (and more expensive) to use underpinning, slurry walls, secant pile walls, or some other similar, stiffer system.
If it appears that lagging will be difficult to install and that ground could be lost while installing the lagging, then soldier beams may not be the best support wall.
Soldier beams with lagging are usually the cheaper support wall. Usually, the soldier beams and lagging get abandoned in place when the excavation is backfilled. Rarely are soldier beams removed. Sheet piling is almost always removed after the excavation is backfilled.
Specialty design/build contractors who specialize in excavation support almost always chose soldier beams and lagging as their 1st choice. General contractors, frequently choose sheet piling as their 1st choice because they often own and reuse sheets and do not want to buy soldier beams and lagging.
Railroads usually require the use of steel sheet piling and allow soldier beams and lagging only if the sheet piling can not be driven as required due to ground conditions such as obstructions and high bedrock.
Does this answer your questions?
