Are you having the rotor balanced, or responsible for having it balanced?
Or, wanting to become familiar with some of the specifications?
Is this a commercially available product?
New, or being overhauled?
The compressor manufacturer should have a thorough overhaul and assembly procedure, and it should include balancing information as well.
Although it might be "send the rotor back to the factory."
Special procedures are needed to successfully balance flexible rotors .
The process can be quite complicated, even when for a fully developed mature product.
Stuff like -
- low speed balancing of individual components to their 2.5 tolerance
- careful assembly paying special attention to component fits and runouts at every stage of assembly
- a low speed balance of the assembly using very specific correction planes inboard from the ends, and possibly non contact sensors at positions along the rotor to detect "whipping."
The final step is usually trim balancing the installed assembly at operating speed.
Pretty complete but cumbersome flexible rotor information here -
"Balancing to ISO G 2.5" is just the iceberg's tip. Which is not trivial by itself either to accomplish, or to inspect.
It is WAY more than a computer printout of the final readings in the balance machine.
