what’s this error?
  • Thread starter Thread starter rabinson1
  • Start date Start date
R
rabinson1
Guest
hi everybody.... I have a problem in mechanica application .... when I wanna use "define material " or " review result" in mechanica application, see this error :"this functionality requires mechanica to be installed"......
what's this error and how can i solve it ?
This error means you need Mechanica to be installed.
If it is already installed then you may need to run through your Pro/E setup to point it to the location of your Mechanica installation files.
I'm not sure how you would review results since you need Mechanica installed to run the simulation?
Edited by: pjw
