M
michaelpaul
Guest
Okay, I know what he red dot means. it means that an edge is gone. I get it. but WTF does the yellow dot mean? If I pick the edge with a yellow dot, the edge being rounded is highlighted. If I do nothing (which is always the case) the model regenerates fine but the yellow dot's don't go away. the only way to get the yellow dots to go away (that I've found anyway) is to delete the reference and pick it over again. So, generally I just leave it alone.
My logic is that if there really is a problem the model won't regen properly. If you have a round set with edges that have this yellow dot, the only way to see this is to redefine the feature and look at each edge in the round set. So, to me, it appears that the yellow dot doesn't really mean anything. Am I wrong? and if so, if it really is telling me something important, why is there no other symbol or notification that there may be a problem?
Thanks.
Michael
Thanks.
Michael
