WF 4.0 not keeping modified working directory
Mechv5
30
Hello everybody,
I change the "working directory" in the ProEngineer WF4 and it is ok until I exit the software and start it again - than I have to change it again, because, for some reasons, it will not keep the modified informations. Is this a bug, or I am doing something wrong?
The second questions would be: where can I find the documentation (help files) of the application (in which sub-directory of the installation folder is it saved), because I cannot access it from within ProE?
Thanks in advance.
ProE opens in the same start up directory all the time. If you right click on the icon you use to start ProE one of the items is "Start in" this is the directory ProE will start in. Changing the working dirctory does not change this value. It is not a bug this is how the software is intended to run. As to the help files, that is a question for your ProE administrator.
Peter Stockhausen
Senior Design Analyst (Checker)
Infotech Aerospace Services
