bimr,
Not quoting any specific references on mixed-flow head capabilities, basing it more on convention. I don't guess I know if there is any true engineering spec or "rule" that defines upper limit of mixed-flow head; as there is with the flow (specific speed). Obviously, looking at the catalog, Flowserve can build a mixed-flow that goes up to 350' (actually they use Cascade bowls/impellers, don't have their own). I wonder if it is using multiple stages; or maybe running pretty fast?? I don't know of anyone else that goes that high in a mixed flow single-stage. Would like to see the individual model information for that bad-boy.
To Pumpsonly: I am surprised at your statement on NonReverse Ratchets. Have used them for many years to do just that: stop the pump from spinning backwards; they absolutely will keep the entire pumpshaft from reversing rotation. Of couse to stop the water from backflowing, a check valve should be installed. As to the reason people use NRR's on verticals; yes, mostly to prevent wrongly wired motor from unscrewing things below. However, the best way to prevent this is to ALWAYS uncouple the pump from the motor anytime electrical work is done; especially in large machines.
Lan123,
One of the first things you should determine would be the amount, size, type of solids you need to handle. This will help determine whether or not you need to go with Non-Clog impellers or not. If you do need to go to Non-Clogs; at your volumes you are looking at very special pumps. They will be ENORMOUS. Non-Clogs are able to handle long stringy solids better than typical Propeller or Mixed flow impellers.
One of the areas you should familiarize yourself with the most are the different bearing arrangements offered by the pump vendors. These will be sleeve types and you should familiarize yourself with the different materials, lubrication designs, and bearing carriers. This may be the area of most differentiation among the vendors.
