eric1037
Geotechnical
- Jul 12, 2004
- 376
I have a little construction issue. We have a project where we did the geotechnical evaluation for a single-story, slab-on-grade structure. We encountered medium dense silty fine sand to a depth of about 3-4 feet below the ground surface. The sand was underlain by loose sandy silt to a depth of about 9 feet. The silt was underlain by a relatively clean, medium dense sand. Groundwater was encountered at a depth of about 5 feet below the ground surface.
The foundations were designed to bear at a depth of about 4 feet below the ground surface.
During foundation excavation, it appears that the silt is becoming very disturbed. To make matters worse, it appears that the groundwater is about 1 foot higher than it was in the soil borings. Therefore, it is at, or just below, the foundation bearing level.
For a case like this, we normally recommend undercutting slightly, then pounding 1-inch to 3-inch size crushed aggregate until it firms up.
Does anyone have any other ideas? We have considered dewatering, but the silt is relatively difficult to dewater due to its low permeability. I have also considered placing geogrid at the bottom of the crushed aggregate to help establish a good working surface.
Thanks in advance.
Thanks in advance.
