techky
- Jul 8, 2011
- 30
Hi Guys,
We are under a big dilemma now. Need your kind inputs please.
The submersible pumps ordered is to be cooled using pumping fluid which is ambient temperature. Although we can also supply external water (continuous flow) & filling the cooling shroud to cool the pump motor.
Now, somewhere there happened a grave mistake by specs being overlooked which actually asked for an independent internal cooling shroud. Meaning the cooling fluid is independent of the pumping fluid.
When checked with the manufacturer, they are unable to modify the existing design in any means. Should we do it ourselves, its a big void of warranty which is also a risk.
Ive been exploring ways of handling this & came out with an option. Fabricate a stand with an air-tight tank filled with water.
Apologies & polite note. The pump model is only taken as a reference from catalogues & we don't represent any brand in specific.
Do you have any suggestions please.
Thank you
Thank you
