short of contacting mineral wool insulation mfg's...
in the event of mineral wool insulation becoming wet, does the insulation retain insulation properties once the insulation is dried?
frankly, how is insulation dried with 0.032" lagging applied? i suppose completely removing the lagging & insulation from equipment and then reapply the insulation & lagging. it seems to me that handling wet insulation is fruitless as the weight of water in the insulation will damaged the insulation. also, seems cheaper and more effective in replacing wet insulation that trying to dry it. actually, cheaper to provide a barrier to prevent moisture from contacting the insulation.
thanks!
-pmover
thanks!
-pmover
