I'm thinking non-interference engines were developed shortly after timing belts became popular.
Looks to me like if a valve on any of these 40+ year old OHV engines was left open 0.3 inches or more at TDC the piston would get all Rocky Balboa on it.
Yet I don't recall folks building passenger V8s having to replace parts for other than wear reasons.
Aside from the occasional plastic overlayed timing sprocket losing teeth outright, it seems like chain wear would make starting and running so poor that the car was either fixed or thrown away before actual chain breakage would cause the engine's interfer-osity to be tested.
Then again, there are likely to be only a few preferred at-rest positions of the camshaft that would occur naturally due to balance of spring pressure stuffing the lifters against the lobe.
