Can someone tell me if there is an API spec that governs what material must be using for a structure that mounts to a producing wellhead that will operate at low temperature(-40C)? I have API 4F that covers the structure but it makes no mention of material requirements for low temperature. I recall from a long time ago replacing a 4140 wellhead component with A350 LF2 for the impact strength but I'm not sure what spec that was based on. Your help would be greatly appreciated.
Thank You
Thank You
