Hello Everyone I have been losing my mind over the following:
How do I join two columns a HEB 300 and a HEB 240 through field weld no bolts.
It is a moderately seismic structure.
So I initially thought of using a plate that joined the two elements and then filling the gaps with vertical plates, also welded. This gives the appropriate moment and shear capacity in the strong axis. But it fails in the weak direction for moment when I apply the weak moment Mn of the HEB column.
I would really appreciate some help thank you
