welding P20 tool steel (nitrided) 1
AU
Hi I work in the tooling industry, and we often repair damaged tools that have been nitrided. For this we use TIG welding, but we usualy have a problem of bubbles forming in the weld, due to nitrogen in the steel from the nitriding process. We grind some off the area and this helps to a degree but we still get bubbles around the edges. Has anyone found a way to overcome this problem. Thanks, Harvey
You could completely “denitride” the metal and then weld and the nitride the part. Another approach might be to change the welding procedures to use a flux cored electrode.
There is some information on this website. Also I try to find my information on some of the particulars of the “denitriding” that we accomplished.
Are you concerned with one tool steel or several?
Thanks for the reply unclesyd, I think we have had de nitriding done before, and still had problems, The process requires heating the whole die plate, something you don`t wont to do unless absolutely necessary. The tools are P20 tool steel and can have mirror finish in the cavitys.I don`t know much about flux cored electrodes I will look into that.Thanks.
