PressEquip
We're trying to develop a weld overlay of nickel alloys onto carbon steel. Client wants to achieve minimum of 1/8" THK of electrode chemistry at the final surface (Spark Test at the surface must have results that fall into the electrode chemistry requirements per ASME Sect. II, Part C (SFA-5.14).
We've tried sub arc and are getting too much iron dilution (even after 4 layers of sub-arc overlay, it's no guarantee the iron will be within range (max 5%wt))
Has any one have experience with hot wire tig for weld overlay of high nickel alloys? If so, please elaborate on what welding equipment and welding procedure details.
If we buy a hot wire tig set up, I would like to build on others experience and purchase a proven set-up.
Thank you for your time
A Fan of EngTips, share the knowledge
